How to get slope attribute from dwg polygons
  • Oct 14, 2019 2:57 PM UTC
  • 7 replies
  • 194 views
clowncutie
Forum|alt.badge.img+7
Hi, I have:
1. A .dwg file of a single 1 ground surface model that i read in.
2. I use GeometryPartExtractor to extract IFMEMesh and IFMEFaces so I get a trianglor network of the model.
3. I then I use GeometryCoherer to get FME_polygon
How do I get the slope (and possibly aspect) for each individual face? I tried SurfaceModeller and it is not working for me since it is creating extra triangles that I do not want.
I have created a custom tool that calulates FME color based on all incoming attributes, ex a test where I add a step 4 where I use surfaceModeller to create the surface again just to get the slope value then I use a DWGStyler to set the surface color to my calculated color and that works fine.
My problem is that I do not like the surface modeller since I already have my model and the extracted version as it is, and NOW I want to get the slope for each individual Face or Mesh, set the color for each triangle and possible use the aggregator and write to a dwg file again.
I have not found a good solution in the community since they all use SurfaceModeller and I want to keep the dwg attributes and extended settings and whatnot.
We say a low slope is white, medium is green and too high slope is red, in a gradient, I sucessfully tested the color tool but I do not know how to extract the slope
From this
to this I need the slope
for each polygon wihtout loosing or editing the model
Best answer by daveatsafe
Hi @clowncutie,
You can use a couple of couple of transformers to get the slope:
- The PlanarityFilter will calculate the surface normal parameters if Expose Surface Normal is set Yes.
- The slope angle can be calculated from the surface normal Z component using the inverse cosine in an AttributeCreator.
This process works best on individual faces. You can extract the faces from a mesh by using the GeometryCoercer to convert the mesh to fme_composite_surface, then a Deaggregator to break the surface up into faces (with Split Composites set to Yes).
@clowncutie Did you try (or find) the SlopeCalculator on FME HUB?
daveatsafe
Forum|alt.badge.img+24
  • Oct 15, 2019 6:03 PM UTC
Hi @clowncutie,
clowncutie
  • Oct 16, 2019 6:57 AM UTC
I did, but it only accepts polylines and I'm not sure if it will be accurate slope if I just take a center line or similar. I looked into alternatives of using the normal vector of the objects
clowncutie
  • Oct 16, 2019 7:10 AM UTC
Hi @clowncutie,
Any more settings to the deaggregator? Because it dont have any output
clowncutie
  • Oct 16, 2019 7:12 AM UTC
Hi @clowncutie,
No, the GeoMetry Coherer sont work with composite surface, my geametryPartExtractor is set to
for $geom in //geometry
where $geom/parent::geometry/@fme_geometry_type = 'IFMEMesh'
or $geom/parent::geometry/@fme_geometry_type = 'IFMEFace'
return number($geom/@fme_id)
It onyl returns meshes now
Forum|alt.badge.img+54
  • Oct 16, 2019 7:14 AM UTC
It doesn't look like the geometries are getting coerced, so there's nothing coming out of the coerced port to go into the deaggregator
clowncutie
  • Oct 16, 2019 10:32 AM UTC
Hi @clowncutie,
Thank you I solved it, I added https://knowledge.safe.com/questions/3204/how-to-convert-a-3d-polygon-into-a-surface.html a step where I composite it to multisurface first then use your solution afterwards to thank you!
