we are searching for a solution to create seamlines between aerial photos.
So we have a lot of photos with different overlapping areas like this:
Is there a possibility to create seamlines between the images? So we wouldn´t like to do this manually. It should be approximately the center line of the overlapping areas. At the end we wanna cut out the origin arial images based on the seamlines. Does anyone have experience with this?
