How to Georeference a PDF?
  • Oct 2, 2023 9:17 AM UTC
  • 7 replies
  • 275 views
aron
Forum|alt.badge.img+16
Using two files: a PDF with no geodata, and a georeferenced polygon. They cover the exact same area (bounding box of PDF = polygon). The polygon and the PDF were originally created in the same coordinate system. There should be no need for "warping". Its just only the georeferenced coordinates in the PDF that are missing.
Q: How do I georeference the PDF using the polygon?
nielsgerrits
Forum|alt.badge.img+67
Multiple ways to do this, but one way is to use the AffineWarper. You need to generate from - to lines with two points based on the unreferenced bounding box and the georeferenced polygon, these are the control features. From these the transformation parameters will be calculated. Features entering the Observed port will be transformed with these parameters.
aron
  • Oct 2, 2023 9:30 AM UTC
Thanks!
You mentioned multiple methods, which method is the quickest in your experience? The PDF-files in question are beasts.
itsmatt
Forum|alt.badge.img+48
  • Oct 2, 2023 9:31 AM UTC
If it's just an offset which need to be applied you can use an Offsetter
You will need to know the difference between the x,y of the lower left corner of the bounding box and the lower left corner of the PDF.
the offsetter will shift the data by the provided x and y components.
If, however, your PDF has been scaled and/or rotated then you'll need to use an Affiner transformer - the Affiner transformer requires that you provide a TransformationMatrix e.g., https://en.wikipedia.org/wiki/Affine_transformation#Image_transformation
There might be an easier way but off the top of my head I can't think of anything
aron
  • Oct 2, 2023 9:44 AM UTC
I forgot an important piece of info.
The polygon and the PDF files were originally created in the same coordinate system. There should be no need for "warping". Its only the georeferenced coordinates in the PDF that are missing.
nielsgerrits
Thanks!
If it is only scaled and moved you can use a Scaler and an Offsetter.
nielsgerrits
Attached sample workspace demonstrating the AffineWarper.
AffineWarperSample(2021)_result
aron
  • Apr 10, 2024 4:49 PM UTC
In case it is of use to anyone else, I ended up scavenging what I needed from the excellent FME Hub transformer ‘BoundsFitter’.
