How to create File folders from excel column
  • January 14, 2025
  • 5 replies
  • 34 views
tamadur
I have Excel sheet with 2 fields, and I need to create folders with the values of the field
tomfriedl
Forum|alt.badge.img+13
  • January 14, 2025
You can use the SystemCaller to start Windows-Cmd:
Command:
cmd /k "md c:\temp\test2 & exit"
Forum|alt.badge.img+49
Do you just want to create folders, or also write data to them?
tamadur
  • January 14, 2025
Command:
thanks i will try
tamadur
  • January 14, 2025
yes, just empty files by names of values attribute
tomfriedl
  • January 14, 2025
You can write Textfile’s. With the params
Write Last Line Terminator = no
Write UTF Byte Order Mark = no
will create files with 0 Byte. Missing folder create the writer automatically folder.
