How to convert a point to polygon
joe.fme
Forum|alt.badge.img+4
Hi all, I have a couple of point features which are feeding through with polygons (as the points should join to polygons, bar these 2). I've tried the GeometryCoercer and CenterPointReplacer etc but no luck. Is there something I'm missing which could create even a small polygon from a point?
dustin
Forum|alt.badge.img+30
  • August 23, 2022
You could use the Bufferer, which will create a circle polygon around each point.
joe.fme
  • August 23, 2022
Good idea! Will try. Thanks
joe.fme
  • August 23, 2022
Update - I seem to get both of them rejected with these values
dustin
  • August 23, 2022
Could you share your log file?
joe.fme
  • August 23, 2022
I can't really due to the folder and feature names, but with the bufferer bit, it returns this. No errors etc, just to rejected -
2022-08-23 14:05:39|  0.3| 0.0|STATS |Bufferer_BUFFERED Feature Counter -1 2147614888 (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2022-08-23 14:05:39|  0.3| 0.0|STATS |Bufferer_<REJECTED> Feature Counter -1 2147680424 (TeeFactory): Cloned 2 input feature(s) into 0 output feature(s)
2022-08-23 14:05:39|  0.3| 0.0|STATS |Destination Feature Type Routing Correlator (RoutingFactory): Tested 0 input feature(s), wrote 0 output feature(s): 0 matched merge filters, 0 were routed to output, 0 could not be routed.
dustin
  • August 23, 2022
Are your points 2d? According to the documentation the rejected port is for non-2d features. If you want the translation to continue regardless of the rejected features, you can change the parameter in the screenshot below to Continue Translation. Sometimes you can glean more information about the rejection if you let the translation continue through.image
joe.fme
  • August 23, 2022
It does continue on rejected features - appreciate the help though, seeming to struggle with the simplest of bits!
Edit - had a change round and chose "ground units". Got it working! Thank you
