How make loop with blocking transformers in fmx?
  • Aug 24, 2020 12:50 PM UTC
  • 10 replies
  • 456 views
Main workspace:loop1LoopingAndBlocking.fmxloop2This gives me error:
> Custom transformer 'LoopingAndBlocking' does not have a port named 'PrivateInput' which is suitable for parameter 'LOOPBACK_INPUT_TAG'
Settings:
Enable blocked looping: Yes
Max iterations: 100
Attribute to hold iteration count: FME_LOOP_ITERATION_COUNT
Using ALWAYS LINKED
Publishing the PrivateInput Port does solves the LOOPBACK_INPUT_TAG problem, but then my feature are outputed through the Incomplete port. That suggests they could not be looped at all?
Any thoughts appreciated. Attaching fmw + fmx
  • Aug 24, 2020 2:13 PM UTC
What are you trying to accomplish? I'm having difficulties understanding the logic.
  • Aug 24, 2020 2:17 PM UTC
I have a more complex workspace where I need to loop over a custom transformer containing blocking transformer(s). Having errors with that I reproduced as small as I could here, so it does not really have a purpose :)
  • Aug 24, 2020 3:11 PM UTC
Did you go through this tutorial first: https://community.safe.com/s/article/looping-with-blocking-transformers
As well as this: https://s3.amazonaws.com/gitbook/Desktop-Advanced-2019/DesktopAdvanced5CustomTransformers/5.11.CustomTransformerLoops.html
  • Aug 24, 2020 3:57 PM UTC
I tried the first tutorial in 2020.1 and experiencing similar errors. Sometimes it seems there is some erratic caching on the port definitions.
Example:
  • In the fmx, create a new output port X
  • Save
  • In host script, delete custom transformer
  • Re add custom transformer
  • Ensure see linked symbol/color
  • The X output is not there!
Other updates do work:
  • In fmx, add a Terminator on an existing input port
  • Save fmx
  • Readd custom transformer
  • Run - it terminates proving it has been updated
jdh
Forum|alt.badge.img+41
  • Aug 24, 2020 6:51 PM UTC
I have found that blocked looping doesn't work with private input ports. It's annoying as there is no good reason for the loop input to be visible on the custom transformer. I usually name it some variation of DoNotUse.
dbaldacchino1
Forum|alt.badge.img+14
I am observing the same thing. Wasted a lot of time this afternoon chasing this issue :(
bo
Forum|alt.badge.img+10
  • Feb 1, 2022 1:42 AM UTC
Thanks! Wish this can be fixed soon.
caracadrian
Forum|alt.badge.img+23
  • Feb 1, 2022 6:04 AM UTC
I usually put the looping part in a custom transformer inside the custom transformer when I have to deal with blocking. This spares me of the looping input not being private and editing the transformer in a different instance of FME.
Try it as a workaround if it suits your workflow.
barrett_h
Forum|alt.badge.img+5
  • Mar 18, 2022 1:44 AM UTC
Hi @caracadrian​, I was just wondering if you might be able to provide an example of nested custom transformers being used to work around blocking with looping? I'm trying to build something similar myself but am not having much success. Thanks in advance.
caracadrian
  • Mar 18, 2022 5:13 AM UTC
@barrett_h​ take a loop at this one that I uploaded to the fme hub https://hub.safe.com/publishers/caracadrian/transformers/eterra3-ancpi-rogeometryfetcher
