How do I convert dwg to svg while maintaining style information (line / fill colors and line widths)?
  • September 4, 2015
  • 160 views
g_tz
Hello all,
FME (and Autocad) noob here.
I am trying to convert a few thousand small DWG files to SVG. This works well with the Real DWG reader and SVG writer; however, I am having difficulty finding a way to set the SVG line width and polygon fill colors from the respective autocad format attributes. Any way I can achieve this without manually writing SVG-tags?
Cheers
Götz
Best answer by gio
i think u have to write it into the style format parameter in the writer.
U can check incscape formatting by opening the xml editor in incscape, if you select an object and expand its tree in the xml-editor you can see the required format.
for example:
fill:none;stroke:#c40000;stroke-width:5;stroke-linecap:butt;stroke-linejoin:round;stroke-opacity:1;stroke-miterlimit:4;stroke-dasharray:40,5;stroke-dashoffset:0;marker-start:url(#Arrow1Lstart);marker-mid:url(#DotL);marker-end:url(#Arrow1Lend)
You can use fme to construct the style string using the autocad format attributes.
colors are hex i believe like in the example  stroke:#c40000
gio
Forum|alt.badge.img+15
  • September 4, 2015
for example:
