How DecimalDegreesCalculator is calculating the coordinates?
skime
Hello, is it possible that someone share with me the knowledge how DecimalDegreesCalculator transformer exactly is calculating the decimal degrees from Degrees Minutes Seconds (DMS)? Is this the formula for it?
 Decimal Deg = Deg + Min / 60 + sec / 3600
Best answer by takashi
I think so, if the Deg is positive value. Why not confirm that with a workspace like this?
  • April 17, 2020
mark2atsafe
Forum|alt.badge.img+44
  • April 17, 2020
If you copy the transformer and paste it into a text editor, you can see the code (including typo in the comment!) that runs the conversion:
# Comvert to decimal and set the attribute
Tcl2 proc DecimalDegreesCalculator_dms2decimal {} {                    \
  set deg [DecimalDegreesCalculator_fetchAndTrimOffLeading0s {ParkId}]; \
  set min [DecimalDegreesCalculator_fetchAndTrimOffLeading0s {ParkId}]; \
  set sec [DecimalDegreesCalculator_fetchAndTrimOffLeading0s {ParkName}]; \
  if { [string index $deg 0] == {-} } {                                \
      set decimalValue [expr $deg - $min/60.0 - $sec/3600.0];          \
  } else {                                                             \
     set decimalValue [expr $deg + $min/60.0 + $sec/3600.0];           \
  FME_SetAttribute [FME_DecodeText {_decimal_degrees}] $decimalValue;  \}
So, yes, it's as you say, depending on whether it's positive or negative coordinates.
