I have set of polygons which is county boundaries. And i need to dissolve three nearest neighbors / adjacent polygons into one. and this has to continue till loop ends. But there is no any relationship attribute to group three polygons. in the attached , I manually selected three adjacent boundaries for the methodology how it should work
How can we achieve this using fme?
