How can I create a PGW file instead of a WLD file during conversion from GEOTIFF to PNG?
I want to read a GEOTFF, add an alpha channel and then write a png with a pgw rasterfile.
My Workbench works but only creates wld-files with png.
How can I create pgw-files?
Best answer by ebygomm
You'll have to either use a filecopy writer or a system caller to create the pgw. I'd recommend swapping the writer for a feature writer, you can then use the output to trigger a systemcaller or send to a file copy writer
Create with filecopywriter (original wld file remains)
Rename with system caller - wld file renamed
jdh
Forum|alt.badge.img+28
  • October 15, 2019
The pgw file is just a wld file with a different extension.
Renaming the file should work.
  • October 16, 2019
Thank you!
Is it possible to rename the files during the process in the picture?
Forum|alt.badge.img+34
  • October 16, 2019
  • October 16, 2019
Thank you!
For what is the ListExploder?
  • October 16, 2019
jmh wrote:
Thank you!
If you are writing several png's at once, the names of them are returned in a list from the summary port of the FeatureWriter, this needs to be exploded so that you rename the wld file for each output png
  • October 16, 2019
Thank you! It nearly worked.
I used the the systemcaller to rename the files with this command line:
C:\\Windows\\system32\\cmd.exe /c "ren "OutputFldr\\*.wld" "*.pgw""
I got the desired PNG+PGW files.
BUT I always get an fatal error that the PNGRASTER writer failed to obtain raster from feature. "Only features with raster geometry are expected"
I can't find the problem...
  • October 16, 2019
Can you share a screen print of your workflow, it sounds like you're sending a non raster feature to the png writer
Edit: you've already written the file with the featurewriter, there is no need for the original writer after the system caller. You are sending a non raster feature into that writer, hence the message.
  • October 16, 2019
Thank you so much! It works!
  • October 16, 2019
If you're using the rename statement posted above, you don't actually need to explode the list, you can just go straight to the systemcaller
  • October 16, 2019
Do you mean that one?:
  • October 16, 2019
Yes, that will rename all files with extension wld to pgw. So you only need to call it once, not once per png
  • October 16, 2019
Ah I understand...
Thanks a lot!
