I have used the 'filecopy' writer. The workbench works fine within FME desktop but when I run as a 'data stream' within FME server I get a message saying 'There was an Error'. See attached screenshot. I guess the question is, is it possible to 'data stream' a PDF. And if it is, should I be using a PDF writer?
Hi, I'm wondering if it possible to 'data stream' a PDF document? Attached is my workbench. The workflow is: Call a reporting engine via a HTTPcaller which returns the PDF I'd then like to publish this to a datastream service. Is this possible?
Best answer by bearman
Thanks for the assistance. I was able to get a solution to this by including the AttributeFileReader transformer. See attached workbench.
