Hi! I am beginner in FME and joined the community only recently. I want to calculate the density of a point cloud (las/laz format, about 6 750 386 points, 1000kmx1000km area).
  • Mar 9, 2023 9:28 AM UTC
  • 101 views
pointclouddensitySo far, I tried two approaches.
  1. Read pointcloud--> extract bounds-> tile point cloud into 1mx1m raster-->extract number of points per point cloud-->sort the number of points--> aggregate the number of points into groups-->write to csv
  2. read point cloud-->extract bounds-> calculate density by PointClouddensityCalculator--> rasterCellCoercer to extract the number of points into z--> coordinate extractor to get 3d points--> aggregate z (which corrsponds the number of points-->sorter-->write to csv
The problem with both approaches: it takes a lot of time (more than 1 h) . Does anyone have an idea how I could calculate the density quicker?
I add a screenshot of my workspace.
I appreciate any help. Thanks in advance!
Kind regards,
Ingrid
jkr_wrk
Forum|alt.badge.img+37
  • Mar 9, 2023 12:04 PM UTC
If you create a small sample set so the run-time does to around 2 minutes. What transformer seems to be the biggest impact on your process?
Why do you sort the points?
Why do you aggregate? Maybe a statistics-calculator is faster
Maybe a counter, with a group-by is faster.
I can't follow your second approach, the densityCalculator is a customTransformer, is it editable? What steps are done there. The first approach seems way more efficient, but maybe your result is not what you want?
Hey jkr_da,
thank you very much for your response. I think I now know why it took so much time. I had the caching on.
I want to calculate the density of the point cloud. Therefore, I divide the point cloud into a 1mx1m raster. I then calculate the number of points in each tile, hence the PointCloudPropertyExtractor. I sort the number of points with the Sorter to be able to aggregate ( as I want to group the number of points , my goal is to know how many squares have, e.g. 1 point, 2 points etc).
Thank you again for your help.
