Hello! My team is using the Socrata Writer to load some large datasets (1-2 million records) daily. I noticed that there isn't a "Features per Transaction" param for this writer. Do you have any suggestions for speeding up writing?
  • Apr 20, 2021 10:17 PM UTC
  • 79 views
These jobs currently take 1-2 hours to run on FME Server (6 CPU, 48 GB) each day. Due to the nature of the data source, incremental updates are not possible at this time.
  • Apr 21, 2021 8:20 AM UTC
It seems that FME has no transaction support for the Socrata writer, see https://docs.safe.com/fme/2020.2/html/FME_Desktop_Documentation/FME_ReadersWriters/safe.socrata.socrata2/quick_facts_safe.socrata.socrata2.htm
I have no experience using Socrata, but based on the way FME uploads the data, I'm not sure transactions would make much sense: "The Socrata Writer works by saving output features to a CSV file, which is then uploaded and transformed using the Socrata Publishing API." See https://docs.safe.com/fme/2020.2/html/FME_Desktop_Documentation/FME_ReadersWriters/safe.socrata.socrata2/safe.socrata.socrata2.htm
  • Apr 27, 2021 1:47 AM UTC
Thank you @david_r​! The documentation is a good reference. "Features per Transaction" may not be the right terminology. The issue I'm having is that the Socrata Writer outputs the features to a CSV rather quickly, but then uploads only 1,000 rows at a time using the Socrata Publishing API. This parameter does not appear to be configurable.
