Geopackage data to Geodatabase with right attributs
  • Sep 27, 2023 9:16 AM UTC
  • 413 views
Hello! I have problem to write several geopackage data to one geodatabase. I used Attribute filter and Dynamic writers. Attributes from all objects comes to each features. How to write data to geodatabase so that there are each features has own attributes?
I am not profs with FME yet :)
Would be thankful for tips.
evieatsafe
Forum|alt.badge.img+28
  • Sep 28, 2023 12:04 AM UTC
Hi @di_777​ thanks for your question! You may need to use a SchemaScanner so that you can use the Schema Source and Schema Definition Name (in the dynamic writer shown in your image). Here's some resources on how you can achieve this:
Happy to help!
  • Sep 28, 2023 5:33 AM UTC
Happy to help!
Thank you!!! I will try it.
  • Sep 28, 2023 12:53 PM UTC
Happy to help!
Is SchemaScanner possible to apply to geometry objects? I have FeatureTypes in my Reader (geometry+object type+attribute/schema).
