geometry coercer
  • October 10, 2014
  • 10 replies
  • 112 views
franco69
Forum|alt.badge.img+11
I have country border lines as a polygon and want to convert them in polylines....but the result should be that tere is only one line on a common border.....so no double lines...
Thanks and Greetz
Franco
gio
Forum|alt.badge.img+15
  • October 10, 2014
Coerce the polygons to lines.
Use topologybuilder, input the lines.
Output lines is result u wish.
franco69
  • October 10, 2014
i tried that....he splits the polygons in polylines...thats ok...but i have two lines on a acommon border...can i remove that when they are same in geometry?
gio
  • October 10, 2014
You can use the matcher. Match 2D and set lenient matching to yes.
Output sinlgematched and not matched.
  • October 10, 2014
The TopologyBuilder generates a single line for a shared boundary of adjacent areas if the boundary lines exactly match. I guess there are slight gaps between them.
If so, the Matcher doesn't work as expected unfortunately.
Firstly check if there are such gaps.
gio
  • October 10, 2014
Hi Takshi,
You would expect that, but it is not true.
If i use topology builder on community dataset (community borders), wich is  topoligy correct, no gaps no overlaps, it does create 2x the edges where they match.
Franco is right, so a matcher is required. Also it must be set to lenient matching else it will not match (wich i find strange).
Maybe the transformer is flawed?
franco69
  • October 10, 2014
Hi all,
the interesting thing that the result is that sometimes there is only one line, sometimes there are two lines....hmmm...
gio
  • October 10, 2014
correction.
When u enter the areas in the topologybuilder this is true, u get 1 line at borders. (wich is where Takashi is right..)
When u coerce them first to polylines and enter the polylines in the topology builder, you get double lines at borders..
  • October 10, 2014
Really?
I always can get single lines for common boundaries, if those are exactly match.
Strange.
franco69
  • October 10, 2014
Right....without coercer it works...;-))
  • October 10, 2014
Ah, the doubt has been cleared ;)
