Geodatabase raster nodata
  • Mar 27, 2018 3:10 PM UTC
  • 119 views
I have a raster dataset stored in a file geodatabase and when I read this into a workbench the nodata bit masks for each band are merged into a single additional alpha band named geodb_nodata as default and stated in the help documentation.
When I view the grid in the inspector Band 0 contains data values and a value of 0 or -3.40282e+38 for nodata cells. Band 1 (ALPHA8): geodb_nodata contains a value of 0 for nodata and 255 for cells containing data.
My question is how can I set the values in Band 0 as nodata using Band 1 (ALPHA8)?
I assume it's a combination of using the RasterSelector with the RasterBandNodataSetter transformers, but no combination has worked for me so far.
Specifically, I want to set the values in Band 0 to nodata using Band 1 and then sending the output to a RasterCellCoercer transformer to create points for all raster cells containing a value i.e. excluding nodata cells.
Thanks
Best answer by jamess
After some more trial and error I have a solution using a RasterExpressionEvaluator followed by a RasterBandNodataSetter. The expression I've used is if(A[1] == 255,A[0],-9999) then I use the RasterBandNodataSetter to set -9999 values as NoData. This works ok, but it would be tidier to set NoData directly in the RasterExpressionEvaluator if possible.
I'd be interested in hearing other suggestions and workflows.
  • Mar 27, 2018 3:12 PM UTC
fmelizard
Forum|alt.badge.img+22
  • Mar 27, 2018 10:40 PM UTC
Hi @jamess,
Thanks a lot for sharing your results with us on this workflow. It's a tricky problem here because like you've no doubt discovered the are essentially two no data values coming in from the raster here (0 and -3.40282e+38). I think the workflow you have suggested is the best workaround for this. While it seems convoluted I think it is a good approach to this particular problem.
