FME date field (%Y%j) to a number
How do I convert an FME date field (%Y%j) to a number so that I can complete arithmetic comparisons?
Best answer by takashi
The DateFormatter can be used to change date format. But I think %Y%j format is available to perform comparisons {<, <=, >, >=, ==, !=}. What kind of comparison do you need?
Takashi
  • June 5, 2014
Takashi
  • June 6, 2014
Thanks for responding Takashi.  I was having trouble comparing two dates because I wanted to add 5 days to one of the values before comparison.  I managed to do it myself last night by using the Tester transformer (after formatting both dates as %Y%j) and adding 5 days to one of the dates in the comparison rather than before the comparison:
Date1 > @evaluate(@Value(Date2)+5)
  • June 7, 2014
You can compare 2 date strings in %Y%j format with the Tester, but as far as I know, existing FME transformers cannot do date calculation. e.g. a date + 5 days.
If you need to perform date calculation in a workspace, consider using script.
# Python Script Example (for PythonCaller)
# Assume input feature has attributes called
# '_year', '_month', '_day', '_diffDays'.
import fmeobjects, datetime
def addDays(feature):
    year = int(feature.getAttribute('_year'))
    month = int(feature.getAttribute('_month'))
    day = int(feature.getAttribute('_day'))
    diff = int(feature.getAttribute('_diffDays'))
    newDate = datetime.date(year, month, day) + datetime.timedelta(days=diff)
    feature.setAttribute('_newDate', newDate.strftime('%Y-%m-%d'))
  • June 7, 2014
ah, I found a custom transformer called DateCalculator in the FME Store. It can be used to add days to a date.
