FME 2024.1 SharePoint Reader
jacintasomers
I have a workspace created in 2023.2 that reads an Excel workbook from a SharePoint library. It is working perfectly.
I have upgraded to 2024.1 and the reader no longer works as expected. If I use the 2024 Data Inspector I can connect to the workbook and see the data. The FeatureReader obtains the schema and the number of records in each sheet and gives a “Translation was SUCCESSFUL” in the log.
The issue happens after that - I get some sort of (possibly) Python related error. Log file of messages after the successful log entry is attached.
I have tried changing the Python version but it didn’t make any difference.
Has anyone had the same issue or any ideas what I could try to get it working again.
birgit
Forum|alt.badge.img+16
  • September 11, 2024
Do you use the sharepoint online connector in your workspace? I think I can remember having problems with this transformer but not necessarily in FME 2024. If this is the transformer you are using can you remove the transformer from your workspace, save, open an empty workspace, uninstall the sharepoint library (tools>FME Options>FME Packages), open your broken workspace and add the transformer again and check if it's working now?
jacintasomers
Thanks for the reply. I tried your suggestion but it made no difference.
It’s a Feature Reader in a brand new workspace trying to read in an Excel from a SharePoint library. The SharePointOnlineConnector transformer works fine. There’s nothing else in it at all.
evieatsafe
Forum|alt.badge.img+18
  • September 18, 2024
Hi @jacintasomers have you tried re-authenticating your SharePoint connection? Has anything else in your environment changed since the upgrade? (permissions, security settings, SharePoint admin settings, etc.?)
If this issue persists, perhaps you can submit a support ticket with us so that we may investigate further. https://support.safe.com/hc/en-us/p/Support
jacintasomers
  • September 23, 2024
@evieatsafe thanks for your reply. Yes I re-authenticated but had no joy. Everything is the same and the connectors continue to function in previous versions of FME. I can see the preview of the Excel sheets when setting up the transformer and also open it with no issues in the Inspector.
There seems to be a successful translation with the error coming afterward.  I’ll log a ticket thank you.
arnold_bijlsma
Forum|alt.badge.img+14
Did you upgrade your reader, writers and/or transformers when moving to v2024.1?
Do you still have the problem when running it with a non-upgraded workbench, i.e. still using the 2023 readers, writers and transformers?
sean.bullock
  • October 30, 2024
I am seeing the exact same thing. Before upgrading to 2024.1, a workflow that I use frequently functioned without issue. Since the upgrade, I too see a Python-related error when reading from an XLSX file that is stored on SharePoint.
Even with a vanilla workflow that contains only the reader, it still fails to run.
Traceback (most recent call last):
  File "weakref.py", line 590, in __call__
  File "C:\Program Files\FME\python\urllib3\connectionpool.py", line 1135, in _close_pool_connections
    conn.close()
  File "http\client.py", line 1020, in close
  File "socket.py", line 505, in close
  File "ssl.py", line 1311, in _real_close
  File "socket.py", line 499, in _real_close
OSError: [WinError 10093] Either the application has not called WSAStartup, or WSAStartup failed
Exception ignored in: <finalize object at 0x10bf8ae0; dead>
    conn.close()
Error running translation.
jacintasomers
  • October 30, 2024
I've been in contact with SAFE and if you upgrade the connector then your workspace might work, it didn't for me. I'm still in contact with them though and hopefully will get to sort it soon in my case.
Strangely I have found that even though you don't use a SharePoint online connector in your workspace, of you add one to the workspace or a bookmark in the workspace where the reader is, if you're running it in pieces, then the reader works. Something to do with how the connection works in the backend if I remember correctly.
vincentochiel
Participant
of note is that I have the same issue with FME Form 2024.1 but in FME 2020.1 the SharePoint reader works.
jacintasomers
  • November 13, 2024
@vincentochiel it works even in 2023, it’s very strange. SAFE are looking into it though.
clang
  • February 4, 2025
I presume this issue hasn’t been resolved? We are experiencing this same behaviour whilst testing FME Form 2024.2.2. We receive the identical error ‘OSError:(WinError 1093)’ when using a FeatureReader to connect to an Excel file hosted on SharePoint, features are read in from the excel file and passed downstream, but the error message is still generated.
As suggested above, using the SharePointOnlineConnector before the FeatureReader, enables the FeatureReader to function correctly. The SharePointOnline connector can reference any SharePoint site.
We have tried re-authenticating the SharePoint connections using multiple domain accounts, that all have full permissions to the source files on SharePoint, to no avail.
We have the latest SharePoint package installed v 1.2.2
However reading from excel files using the FeatureReader, where the files are hosted on a ‘Teams’ SharePoint sites, is successful? I’m not sure what the significance of this is, other than the URL containing the word ‘teams’
https://ourdomain.sharepoint.com/Teams/DataShare
vs
https://ourdomain.sharepoint.com/Sites/DataShare
Any suggestions, ideas welcome as this is preventing us from upgrading FME Server 2022.2 to FME Flow 2024.2.2
crystalatsafe
Hi ​@sean.bullock
Are you still seeing this error after upgrading the SharepointOnlineConnector package to version 1.2.1?
crystalatsafe
Hi ​@clang
Can you submit a support ticket with us so we can look into this issue: https://support.safe.com/hc/en-us/p/Support
Please reference this development ticket number (FMEENGINE-84641) so we can link it to your support ticket.
Thank you!
clang
  • February 5, 2025
Hi ​@crystalatsafe, raised a ticket as requested.
Thanks,
Chris
