Find the nearest line segment to a point with a couple common attributes?
  • October 13, 2023
  • 24 views
dewrightco
Forum|alt.badge.img+4
I have a point array of addresses, and a line geometry layer of streets, and I need to be able to get the ID of the nearest line to the point that also has a couple matching attributes.
What are the best options to consider?
Best answer by nielsgerrits
One way to do this is to use the NeighborFinder. Points as bases, lines as candidates, 1 to find, group by the attributes that should match.
nielsgerrits
Forum|alt.badge.img+54
  • October 16, 2023
