Find beginning of a word in a character chain
Hello guys,
Is there a way to find a word I character chaîne with the tester like in arcgis when I create an sql selection. For exemple with the % at the end or beginning or word?
Best answer by erik_jan
Another option would be the StringSearcher transformer, using regular expressions.
The Tester drop down for operator has a 'contains', 'begins with', and 'ends with' function and then you can either set a static right value or use a variable from an attribute.
erik_jan
Forum|alt.badge.img+18
  • June 22, 2020
