fieldlist without sorter
  • May 25, 2016
  • 29 views
I'm working with a workbench, found on https://knowledge.safe.com/articles/1127/write-mic...
I'm trying to change the order of the columns, writen in the MSwordtable transformer. The order I want to get, is "type", "omschrijving", "VH", "eenheid".
I managed the order of the attributes (with the attributemanager). this can be seen when I uncheck the "sorted" bullet, on the right sight of the image below. (this is the result how I want it)
In the fieldlist parameter, I indicated which columns should be used.
now, this order is not used in die fieldlist parameter, instead, FME uses the order "type", "VH", "eenheid", "omschrijving".
When I look closer, this parameter is always "sorted" (I do not know how it is sorted, definitely not alphabetically).
when I uncheck the "sorted", I get the order like I want (see right part of the image below), but clicking on the OK button makes the sorted bullet again checked.
Is this a bug, or am I doing something wrong here?
I hoped to solve this problem with the attribute manager, otherwise I have to dive into the code of the MSwordtable transformer, in order to try to change the order of the columns there.
I hope someone can help me out!
with kind regards,
Ine De Cubber
erik_jan
Forum|alt.badge.img+26
  • May 25, 2016
HI Ine,
Instead of selecting the field, would it be possible to type the sequence of fields in the parameter box? Or copy "type,omschrijving,VH,eenheid" from a text editor?
I know: not the nicest solution, but hopefully possible.
If not, open the FMW file in a text editor and replace the wrong sequence with the right sequence.
Again, not a nice solution, but most likely a working solution.
Erik Jan
