FeatureReader couldn't read the features with Where statement -TAB file
  • Jul 6, 2021 12:00 AM UTC
  • 96 views
Hi experts,
I want to read the TAB file but with WHERE statement to filter the number of records that I want. It could not perform and run into errors like below. Could you help to indicate where I did wrong. THanks.
I had tried without "" for the fields name, treating the values like string and not string.
Performing query against MAPINFO_EXTENDED dataset `C:\\QV\\MapData\\PARCEL.tab'
UniversalReader: Unable to emulate search type 'fme_all_features' because fme_where is requested
FeatureReader_2 (QueryFactory): A fatal error has occurred. Check the logfile above for details
A fatal error has occurred. Check the logfile above for detailsCapture
Best answer by danilo_fme
Hi @tranhaiphuong88
I re-created your case in my FME Workbench Desktop using the transformer InlineQuerier.
This transformer creates a temporary SQLite database, and creates a table for each input object that is connected to it. In the parameters dialog, you may create any number of SQL queries that use these tables.
Workspace01The configuration into transformer:
select * from Parks where TreeCount=10
Workspace02Attached the Workspace.
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Sep 20, 2021 1:12 AM UTC
Hi @tranhaiphuong88
Thanks in Advance,
Danilo
that is brilliant. thank you
danilo_fme
  • Sep 26, 2021 10:07 PM UTC
Thanks!
