FeatureJoiner - 2018 Release Candidate
  • Mar 7, 2018 5:31 PM UTC
  • 76 views
So I've been playing around a bit with this new transformer (check out this great post by @Mark2AtSafe https://blog.safe.com/2018/01/data-join-with-fme-evangelist171). When using the FeatureMerger, one trick I use a lot is to simply type the same string or a single character for the supplier and requestor in order to force a join, irrespective of whether the two have any common data. I learned this trick at last year's FME World Tour in Houston if I recall. However this doesn't seem possible with the new FeatureJoiner as it won't accept a text input. You have to instead create a new left and right attribute and supply some common value, then remove the attribute after joining (which is what I used to do before learning that quick trick!).
Is the new FeatureJoiner going to get the ability to input text instead of being forced to pick an attribute? Thanks.
Best answer by mark2atsafe
I'm in the office in Vancouver this week and I'll bring it up with the developers. For sure that does seem an oversight, but there might have been a technical reason for it. I'll let you know what I find out.
mark2atsafe
Forum|alt.badge.img+59
  • Mar 7, 2018 7:40 PM UTC
mark2atsafe
No technical reason, they were just trying to keep the dialog cleaner. The request is filed as PR#82674 and it's been given a high priority because I do think it's a barrier to users wanting to move to this transformer.
