Feature Merger results are not compatible with ArcGIS-Join Results
  • November 30, 2015
  • 5 replies
  • 53 views
I have two tables for blocks data, each block in these tables is identified by its block ID, and I want to find the unmatched blocks between these tables.
In ArcMap, I joined the two tables based on the "Block ID" fields, after validating the join, 822 out of 1496 blocks were matched.
However, I tried to do the same thing using FME, I created a workbench that reads from these two tables, and applied a feature merger on them to compare the "Block ID". However, the results were different; there was 1011 matched "merged" blocks!
I could not figure out why FME results are different from ArcGIS ones. What might be the issue here?
Best Regards,
Hani
erik_jan
Forum|alt.badge.img+26
  • November 30, 2015
Could this because of a difference in length of the BLOCK_ID field in both tables. And then FME trimming spaces from the values?
mark2atsafe
Forum|alt.badge.img+59
  • December 1, 2015
It could be a number of things. I think the important part is to try and identify one of the features that FME thinks is a join but ArcGIS does not. If you can inspect one of those features (and the feature it allegedly matches to) it will help to clarify what the issue is.
  • December 2, 2015
I agree with Mark, try to find one single feature that gets a different treatment in FME and ArcGIS.
That said, I kinda suspect an encoding issue here, seeing as you're matching on (what looks like) arabic characters.
bruceharold
Forum|alt.badge.img+19
  • January 6, 2016
Hi
Like Mark2 hinted, unicode data might be compared by collation order in a geodatabase but byte order by FME, which would cause match differences.
I'm going to pollute the forum with a pointer to an Esri sample that should help you, but hey I do plenty for Safe in my day job :-)
http://www.arcgis.com/home/item.html?id=e638afe069...
fmelizard
Forum|alt.badge.img+22
  • February 6, 2016
Not sure if this ever got resolved. @hani_draidi -- could you send some sample data and the workspace in to support@safe.com and we'll dig in.
