Fanning out different attribute schemas to different Excel tabs
  • December 19, 2024
  • 33 views
p_c_20
Forum|alt.badge.img+8
Am creating three sets of numbers from one source file. Each set has a different attribute structure.
I want to fan these out into separate tabs of an Excel spreadsheet, using a created attribute that is common to the three streams, but has a different value for each.
Have tried every permutation of setting I can think of in the Writer/dynamic schema defn, and cannot get it to respect the three different attribute schemas.
Feels like this should be easy, but…..🤔
Best answer by jdh
If each tab has a different schema, then you need to either send a schema feature in advance of the data features, or have the schema attached to each data feature.
The SchemaScanner is the easiest way to accomplish this.
jdh
Forum|alt.badge.img+28
  • December 19, 2024
