Extracting points from line (SHP)
Hello, I have a .SHP with lines and I need to extract X, Y coordinates as points for start and end nodes of lines and give them an ID. I could have a polyline containing several lines connected, in that case end node of first line is the same point as start point of next line. I tried with CoordinateExtractor, CoordinateConcentenator, AttributeKeeper but had no luck. Is there any solution for my problem?
Best answer by takashi
To extract points {p0, p1, p1, p2, p2, p3} from a polyline p0-p1-p2-p3, you can do that with two Choppers in series.
  1. Chopper (Mode: Vertex, Maximum Vertices: 2)
  2. Chopper (Mode: Vertex, Maximum Vertices: 1)
To extract points {p0, p1, p2, p3} from the same polyline, you can just use a single Chopper.
  1. Chopper (Mode: Vertex, Maximum Vertices: 1)
I don't think you need to use SpatialRelator.
  • May 7, 2018
If a polyline has four vertices p0, p1, p2 and p3, which one is your desired result - {p0, p1, p1, p2, p2, p3} or {p0, p1, p2, p3}?
  • May 7, 2018
@takashi, it doesn't matter. I need to write this points to Oracle DB. First result would be easier, I think, where I would just write to DB, and second i would need to use SpatialRelator before writing to DB.
  • May 7, 2018
  • May 7, 2018
Either one is good, I think i will be using the second one. Thank you @takashi. You are right, i don't need SpatialRelator.
