Extract pixel from raster
danilo_fme
Forum|alt.badge.img+44
Hello Team,
My customer has a source data and the goal is extract just a yellow line from it.
The problem is when i use the transformer ( RasterCellCoercer ) after my source data the time and performance to get the polygons is not good.
I believe the transformer RasterExpressionEvaluator is a right solution to find these values RGB
Attachment my template file.
Thanks in Advance,
Danilo de Lima
jdh
Forum|alt.badge.img+28
  • June 12, 2017
Converting from raster to vector in FME is notoriously slow.
You are on the right track for ways to improve performance. If you use the RasterExpressionEvaluator to create a 1 band image where your yellow RGB value(s) have a value of 1, and everything else 0, and then set the Nodata Value to 0 (RasterBandNoDataSetter) then the coersion should be more efficient.
You can also experiment to see of the RasterExtentsCoercer (DataExtents) or RasterToPolygonCoercer is more efficient than the RasterCellCoercer for your particular data.
fmelizard
Forum|alt.badge.img+18
  • June 12, 2017
Hi @danilo_inovacao Yep you will see a vast improvement in perforamnce if you do as @jdh suggests. For your particular case you can use this expression in the RasterExpressionEvaluator (use Int8 as the
interpretation):
@if(A[0]==255 && A[1]==251 && A[2]==134,1,0)
Follow this with a RasterBandNoDataSetter to set 0 = NoData and then a RasterToPolygonCoercer to get it into vectors and Bob's your uncle! The process shouldn't take any longer than 5 seconds!
jneujens
  • June 13, 2017
The output should be a line or a polygon?
Anyway, I have experienced that a 'Generalizer' after this raster-to-vector conversion can be helpful in further processing. Just saying!
danilo_fme
  • June 14, 2017
Thanks @jdh . Your suggestions was very important for me :)
danilo_fme
  • June 14, 2017
Hi @jneujen, the output is polygon.
Thanks your help :)
