Extract an IFC object from one file and put it in a precise location of another IFC
  • Mar 12, 2024 1:45 PM UTC
  • 216 views
yagami9
Hi ,
Is there any way to use an ifc file containing ifc objects, extract a specific object , then put it in precise locations in another ifc file that I am creating in the workflow?
for exemple if I am interested in using this ifcDoor object that is inside a file1.ifc file :
and the positions where i want to put this ifcDoor are where the 2d doors (the red lines) of my input file are located (my input is a dwg file containg 2D doors):
All I can do now is just extrude those 2d doors , add ifc attributes to them , and them write them to ifcDoor writer .
but they don't even look like doors :
i want the doors to look like the ones in my file1.ifc file (their color , geometry , texture )
I'm searching for a way to do it , but I am afraid that it is impossible .
Best answer by jasperwis
Hi @yagami9
Attached is a workspace to align the IfcDoors with de DWG blocks.
Result:
May be you will need to add a Scaler, if you want the width of the door to match the dwg.
I have also added a SolidBuilder and SolidDissolver to get rid of some disturbing parts.
And I manually selected a good origin point to match the pivoting point of the door.
I haven’t added the ifc writing part yet.
Jasper
jasperwis
Forum|alt.badge.img+19
  • Mar 12, 2024 7:55 PM UTC
Hi @yagami9
This should be possible.
Extract the rotation of the 2d doors.
Use a FeatureJoiner to join the geometry from the IfcDoor
Rotate the IfcDoor with the rotation angle derived from the 2d door
Send this to an Ifc Writer.
Can you share a sample dataset?
Jasper
yagami9
  • Mar 13, 2024 10:00 AM UTC
Hello @jasperwis
Thanks a lot for the help !
I attached a dwg file with a simple floor plan and a an ifc file that I want to use one of its doors geometry (for exemple the door with the name = Haustuer) .
Yagami
jasperwis
  • Mar 13, 2024 12:41 PM UTC
Hi @yagami9
Result:
Jasper
yagami9
  • Mar 13, 2024 2:38 PM UTC
@jasperwis thanks a lot !!! it works
I really appreciate your time and help
