extend a line to an edge of a polygon
  • Mar 7, 2022 9:17 AM UTC
  • 306 views
Hello,
After using the CenterLineReplacer transformer on a ploygon I get the following result.
Is it possible to extend the line that was created before so that it reaches the edge of the polygon?
Thanks for your help
Best answer by nielsgerrits
How I do this:
  • Generate ID for polygon.
  • Generate centerline from polygon.
  • Extend centerline using LineExtractor, using a large number.
  • Clip the centerline by the original polygon, grouped by ID, keeping only inside.
nielsgerrits
Forum|alt.badge.img+67
How I do this:
  • Mar 7, 2022 1:56 PM UTC
How I do this:
thank you for your message. i will try like this
