Esri Portal Connection for Survey123ReportGetter
  • April 6, 2025
  • 23 views
bromp
Forum|alt.badge.img+4
Hi there,
I am trying to generate a survey123 report using FME. I have downloaded and added the custom Survey123ReportGeter transformer however I am using a portal connection instead of an AGOL connection:
After this step i have the Tester that checks for the submit_response_body beginning with {"jobId" however the flow always fails here. I get an invalid token message in my submit_response_body:
{"error":{"message":"498: Invalid token.","code":498},"success":false}
I am not sure if the request URL needs to be different for portal? or if the token i am providing in my query string parameters is not being read in properly…
Any help would be greatly appreciated.
This is what my transformer looks like:
bromp
  • April 9, 2025
I have successfully got the job to submit using the same endpoint:
https://survey123.arcgis.com/api/featureReport/createReport/submitJob
this returns the jobId # and jobStatus of esriJobSubmitted.
I am also able to access this endpoint:
https://survey123.arcgis.com/api/featureReport/queryJobs
however accessing the endpoint that returns the resultFile which should here here:
https://survey123.arcgis.com/api/featureReport/jobs/@Value(jobId)
is still hitting me with an invalid token. Has anyone managed to configure this for their portal before?
Cheers
