Error reading .zip file geodatabase
  • Nov 9, 2020 3:04 PM UTC
  • 97 views
I am trying to read an esri file geodatabase that is zipped but I get this error
Geodatabase Error (-2147024893): The system cannot find the path specified.Could not open File Geodatabase dataset `C:\\Instaplat\\workspaces\\TexasWorkspaces\\INSTAPLAT_PROTOTYPE.gdb.zip' for reading
I have attached a workspace that produces this behavior, any help is appreciated.
Best answer by jovitaatsafe
Hi @garydlester​,
If you are running this workspace on Windows 10 or higher, can you try following the instructions in this article, Windows: Enable Long File Path Support? I suspect the issue is that Windows has a maximum path length restriction of 260 characters, therefore during the zip file extraction, if FME Engine encounters a long path that exceeds this limit, the process will fail.
jovitaatsafe
Forum|alt.badge.img+11
  • Nov 9, 2020 7:25 PM UTC
Hi @garydlester​,
