Equivalent of the ArcGIS "Eliminate"
  • February 13, 2019
  • 6 replies
  • 143 views
Hello everybody, im looking for a transformer that replace the "eleminate of Arcgis", i want to merge the small polygone (less than 5000m2) with neighboring polygons that have the largest area or the longest shared border.
i heard that sliver remover can do it but im not sure
Thanks
Best answer by markatsafe
@hafida115 In FME 2018 the SliverRemover was replaced by the AreaGapAndOverlapCleaner. To expand on @danilo_fme 's comment. You could try using the AreaCalculator & TestFilter to drop the polygon's with areas less than 5000m2 , and then try using the AreaGapAndOverlapCleaner to fill in the holes left behind.
danilo_fme
Forum|alt.badge.img+44
  • February 13, 2019
Hi @hafida115
There is the transformer Dissolver that merge all polygons that are touching.
Before this Dissolver, I suggest you to use the transformer AreaCalculator and after the Tester to filter polygons less than 5000m2.
Thanks,
Danilo
Forum|alt.badge.img+33
  • February 13, 2019
Do you want to merge by largest area or longest shared border, one is more straightforward than the other in fme
  • February 13, 2019
danilo_fme wrote:
Hi @hafida115
Thanks,
Danilo
sorry im new on fme can you explain me how the dissolver work?
thanks
  • February 13, 2019
  • February 13, 2019
thanks the AreaGapAndOverlapCleaner work
danilo_fme
  • February 14, 2019
Thanks @MarkAtSafe to help us with this case.
