Equivalent of ArcGIS Spatial Adjustment (Transformation - Similarity)?
  • Jun 30, 2023 12:38 PM UTC
  • 47 views
Hi everyone,
I have DWG files drawn in local coordinates and I need to transform them to shapefiles in a national projected coordinate system. This is currently done with Spatial Adjustment (Transformation - Similarity) as the links file (.txt) provided has two displacement links:
-1000 -1000 "Destination X Value" "Destination Y Value"
1000 1000 "Destination X Value" "Destination Y Value"
p.s. I've just replaced actual numbers by "Destination X Value" etc.
What would be the best way to replicate this process with FME? If it is Affiner how do I utilise the values from the links file?
Thanks in advance!
hkingsbury
Forum|alt.badge.img+73
  • Jul 2, 2023 8:09 PM UTC
The Offsetter transformer will allow you to translate the feature(s) in Cartesian coordinates.
You also have the Affine and AffineWarper transformers that will allow for some more complex adjustments
