Dynamically setting "Columns" on UPSERT in FeatureWriter to PostgreSQL
johnt
Forum|alt.badge.img+11
I have a dynamic workspace where I am reading in multiple csv update files for multiple feature types to upsert into our database. I had set the primary key dynamically dependent on the target table in the database. I cannot set a where clause on an UPSERT (which I do use with other feature types that have the ability to do I, U, or D) so went to use the "Row Selection: Columns:" section instead. This parameter does not work in the normal way with attributes. It presumes the selected attribute is the primary key field (no orange left arrow in front of the name), rather than using the value. I tried manually adding @Value(primary_key) (the attribute that stores the primary key column name) in the parameter but the feature writer also presumes it is literal and obviously can't find a column called "@Value(primary_key)" and errors.
This is something that I would like to do, and is very much a part of a dynamic workflow. Otherwise I will have to create one dynamic feature writer for each feature type so I can manually set the primary key column - negating the efficiency of using the dynamic workflow. I can see that FME 2023.1 works in the same way as 2022.2.0 (which is what I am working in at the moment.
Is this something that will come in in the future? Should I add it to the Ideas?
danminneyatsaf
Forum|alt.badge.img+12
Hi @johnt​ I just tested dynamic writing + Upsert with the PostgreSQL Writer and was able to get it working correctly.
In the User Attributes tab of your Dynamic PostgreSQL Writer, you'll need to make sure that you've exposed the primary key column so you can use it in the Match Columns parameter.
In my workflow I used the SchemaScanner to create the schema to be used in the writer mid-workspace. You can see how I configured the writer in the screenshot below. Because we're using the schema from the SchemaScanner, we need to set the Schema Source to "Schema From Schema Features" and SChema Definition Name must be set to fme_feature_type_name (this is the name of the corresponding schema feature created by the SchemaScanner). image
I find if I'm having issues with the schema being picked up then the SchemaScanner is a good solution, but it isn't necessary to use if the schema coming from your Dynamic CSV Reader is working fine.
If you're interested in the SchemaScanner, you can find more info here: https://community.safe.com/s/article/How-to-SchemaScanner-Transformer
Hope this helps!
mathiku
Forum|alt.badge.img+7
  • March 6, 2025
Is there a specific technical reason why you can’t use where-clause in Upsert?
evieatsafe
Forum|alt.badge.img+20
  • March 17, 2025
Hi ​@mathiku great question, sounds like this is a limitation on PostgreSQL and other writers that have similar functionality. Looks like PostgreSQL does not have the UPSERT statement but it supports the upsert operation by the INSERT...ON CONFLICT statement. Because of the limitations on the Insert On Conflict statement, it requires an ID that specifies the conflict target, which is the unique constraint or unique index that may cause a conflict. This is a requirement, and why the where clause is disabled.
If you need to use a where clause, a workaround would be to use separate feature types for Insert, Update, and Delete. Or, use the fme_db_operation from the ChangeDetector in the Insert & Update mode.
