dwg to qgis or dwg to postgis for web client
  • January 21, 2020
  • 12 views
Hello
sorry for my English
We want to create a modifiable client web so that the departments are able to create, modify or read on a single map which will be fed by the drawing department
We create layers and attributes in qgis to be able to create and modify it's addition in the client web.
The dwg is only for reference in the web client
editable web client (lizmap) Other departments
qgis connects lizmap with linux server ..postgis
autocad map (drawing dwg) Drawing department
I would like to take a dwg which is still in production by the drawing department ... which will be visible in the client web ...
My problem is that the dwg is not compatible with qgis
Is it possible to send dwg in postgis .. so that I can retrieve it in qgis .... for which can be displayed in the web client
Unless you have another alternative
I don't know if FME products will be a solution for me dwg to postgis
Be specific in your answers
afavaccio
  • January 21, 2020
Hi @jpbeaudoin19 FME it's the right tool for what you need to do, take a look here
