DWG Resolved Lineweight
  • Apr 6, 2020 12:16 AM UTC
  • 6 replies
  • 119 views
deanhowell
Forum|alt.badge.img+24
Is there a way to find out the default (-3) lineweight?
There is an option for autocad_resolved_linetype but can't find a similar option for when lineweight is set to default (-3)
nampreetatsafe
Forum|alt.badge.img+14
Hi @deanhowell: I'm wondering if the autocad_lineweight format attribute is what you are looking for?
Based on the documentation:
deanhowell
  • Apr 11, 2020 10:48 AM UTC
Thanks that is the attribute i am using but one of the values is -3 which is the default and trying to figure out what the default value is.
andreaatsafe
Forum|alt.badge.img+17
Hi @deanhowell,
Are you looking for what the line weight is aka what it resolves to correct (either 0, 5, 9 etc)? Essentially you're looking for an autocad_resolved_lineweight attribute.
Please let me know if that's what you are looking for. If that is what you're looking for, we'll need to see if this enhancement is possible as we'll need to see if the libraries have support to pull this information out.
- Andrea
deanhowell
  • Apr 14, 2020 10:04 PM UTC
Hi @deanhowell,
- Andrea
Hello @andreaatsafe, yes that is exactly what I need, autocad_resolved_lineweight attribute.
There is one for linetype but not for line weight.
andreaatsafe
Hi @deanhowell,
Thanks for confirming!
I've filed an issue for our development team to add in this capability (FMEENGINE-64023). This question has been linked to the issue, so I'll be sure to notify you here when it's been implemented.
- Andrea
deanhowell
  • Apr 14, 2020 11:33 PM UTC
Hi @deanhowell,
- Andrea
Thanks you are a champion :)
