Hello Everyone,
I have a very simple question regarding Coordinate Systems. I found out there were "LL83" and "LL-83" which looked pretty much same.
Do you guys know what is the major difference between those two systems?
Thank you!
Sean
Hello Everyone,
Thank you!
Sean
Best answer by david_r
While in FME Workbench, open Tools / Browse Coordinate Systems. You can then locate both coordinate systems and compare their definitions.
I'm no expert on the matter, but since their OGC/ESRI WKT description is identical I would assume there's no difference between them.
No account yet? Create an account
