Creating attribute values from variable "fme_basename" strings
  • Feb 10, 2015 2:37 PM UTC
  • 151 views
Hi everyone,
Fairly new to FME and having some problems trying to get what I want.
Trying to create polygons from raster extents using the RasterExtentsCoercer tool. I also need to write variable attributes into the resulting shapefile depending on the basename. i.e. the raster files are in a very specific naming convension "mmm_sss_ttt_pp_yyyymmddthhmmss_oooooo_dddddd_nnn.eee". Each part of the string relates to key information that needs to be included in the shapefile. How do I extract this and get it to write to each of the attribute columns?
e.g.
SWATH = sss
PRODUCT_TY = ttt
POLAR = pp
DATE = yyyymmdd
TIME = hhmmss
etc.
I've done this kind of string extraction work before in excel but never in FME so any suggestions would be greatly appreciated.
Many Thanks in advance!
gio
Forum|alt.badge.img+15
  • Feb 10, 2015 4:40 PM UTC
If the naming convention is always the same pattern.
You can either use regexp in a creator or use a stringsearcher with regexp.
A simple regexp like
(\\w{3})_(\\w{3})_(\\w{3})_(\\w{2})_(\\w{15})_(\\w{6})_(\\w{6})_([\\w\\.]+)
If you use stringsearcher you then have to expose _matched_parts{0} to {7} for all 8 captures and then rename them. Probalby want to reformat the datestring too. (there is a DateFormatter transformer)
Or a seriesSubstringExtractors.
  • Feb 11, 2015 11:42 AM UTC
It's also possible to use the AttributeSplitter first, but I agree that the StringSearcher would be a good solution.
In addition, since regular expression is very flexible, there can be many variations depending on the format specification and/or your requirement.
e.g.
You can modify the expression, so that it will split date and time simultaneously:
(\\w{3})_(\\w{3})_(\\w{3})_(\\w{2})_(\\w{8})t(\\w{6})_(\\w{6})_(\\w{6})_([\\w\\.]+)
If you need to split the final part into "nnn" and "eee", "([\\w\\.]+)" can be replaced with "(\\w{3})\\.(\\w{3})".
If a part may contain some symbol such as brackets, you can use "." (dot: any character) instead of "\\w" (alnum: alphabet character, digit or under score).
and so on.
Takashi
