Creating an ArcGIS Pro Layer File in FME
  • February 16, 2023
  • 173 views
od10
Forum|alt.badge.img+4
Hello,
Has anyone ever created an ArcGIS Pro layer file *.lyrx inside FME for use in ArcGIS Pro? For example, converting a *.dwg file into *.gdb, aswell as creating a layer file which holds the symbology from the *.dwg.
Thanks, @Takashi Iijima​ @danilo_fme​ @Hans van der Maarel​
maaw306
Participant
  • Participant
  • December 12, 2023
Did you ever figure this out? Stuck on this now.
dannymatranga
Forum|alt.badge.img+5
  • November 12, 2024
I am wondering the same thing.
madeleine_rfs
Probably the best way would be to use ArcPy with a PythonCaller to modify an existing layer file, using the updateConnectionProperties() function. See link below.
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/layerfile-class.htm
