coordinate system transformation
ca
Forum|alt.badge.img+3
When using the Reprojector transformer FME logs the transformation in the log file. Below is an example from a log file:   Reprojector: Using transformation `NAD27_to_NAD83_Canada_FME,Forward(Grid File Interpolation,EPSG:1313)' when reprojecting from LL-27 to EPSG:4326   Is there any way to ``capture`` the transformation used in an attribute or anything that can be written out?   Thanks,   CA
  • August 9, 2013
This may not be an ideal solution, but it's possible to collect only the messages which match with a specific condition using Python.
A PythonCaller with this script, for example, provides a functionality to collect every message which starts with "Reprojector:".
----- import fmeobjects   g_messageList = []   # Callback function to collect every message # which starts with "Reprojector:". def collectMessages(severity, message):     if message.startswith('Reprojector:'):         g_messageList.append(message)   class LogCallbackSetter(object):     def __init__(self):         # Set the callback function to log file object.         logger = fmeobjects.FMELogFile()         logger.setCallBack(collectMessages)              def input(self, feature):         self.pyoutput(feature)              def close(self):         pass
Insert the PythonCaller before the Reprojector, then you can refer to the messages stored in "g_messageList" using Shutdown Python Script or another PythonCaller.
Example 1: This shutdown script writes the messages into a text file.
----- f = open('C:/tmp/messages.log', 'w') for msg in g_messageList:     f.write('%s\\n' % msg) f.close()
Example 2: A PythonCaller with this script adds the messages to each feature as a list attribute. In this case, a FeatureHolder should be inserted between the Reprojector and this PythonCaller in order to complete collecting messages.
import fmeobjects   class MessageExtractor(object):     def __init__(self):         pass              def input(self, feature):         feature.setAttribute('messages{}', g_messageList)         self.pyoutput(feature)              def close(self):         pass
Takashi
  • August 9, 2013
Correction: There is no need to use a FeatureMerger in Example 2.
Example 3: This script can be used instead of Example 2.
import fmeobjects   def setMessages(feature):     feature.setAttribute('messages{}', g_messageList) -----
Takashi
  • August 9, 2013
... Correction to the Correction (:-( Replace "FeatureMerger" with "FeatureHolder".
fmelizard
Forum|alt.badge.img+22
You could also just read the log file and extract the info, that is if you dont need it for the same translation.
ca
  • August 9, 2013
Thanks Takashi.
That looks like it will do exactly what I need.
CA
