Converting ecw images to jpg,
  • May 28, 2014 12:01 PM UTC
  • 10 replies
  • 858 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out which commands can help in transforming ecw images to jpg.
The ArcGIS fials to convert ecw image with 8 bit pixle depth and unsigned
Thank you
Best
Jamal
  • May 28, 2014 12:07 PM UTC
did you try to connect the ECW reader to the JPG writer? If it didn't work, what did the log say?
David
jamal
  • May 29, 2014 9:37 PM UTC
Thanks David,
It is converted successfully and can be displayed by the “FME Data Inspector”
However, the ArcGIS is not able to display it
What might be the issue here?
  • Jun 2, 2014 8:18 AM UTC
difficult to say, perhaps this particular combination isn't supported by ArcMap? You should perhaps ask ESRI or in the ArcGIS forums about this.
David
gio
Forum|alt.badge.img+15
  • Jun 2, 2014 1:21 PM UTC
I just did an extraction today for a customer.
Ecw to jpg.
I used the jpeg writer as you did.
And it does show in Arcmap.
The only difference i see in your case, as far as i can see, u did not generate a worldfile (.wld)
Try setting generation of worldfile to yes. (format parameters of the writer, can also be set in the navigatorpane)
gio
  • Jun 2, 2014 1:30 PM UTC
Hi again,
I tried it without a wld file.
Without a file it also works, but if u click full extent button (the little globe icon) u get a warning :
"no wld Witte Singel complex.jpg:   The display area covers too many pixels at the current display resolution. Please zoom in or build pyramids.".
If u use "zoom to layer" on it it will pop into view.
jamal
  • Jun 3, 2014 7:45 AM UTC
Thanks GIO,
The option “world file generation” is already set to be “yes”.
What other options do I still have such that the converted ecw by FME can be displayed in the ArcMap?
gio
  • Jun 3, 2014 10:17 AM UTC
Hi Jamal,
There should be no issue displaying the jpeg.
Did u try "zoom to layer" on the ecw layer?
Maybe u have a different projection for the ecw then you have set for the mxd (?).
jamal
  • Jun 5, 2014 9:19 PM UTC
Thanks GIO
The ArcGIS is not able to open it at all. As the jpg is added to the ArcMap, it keeps working and never ends.
What other issues should I consider?
  • Jun 6, 2014 5:50 AM UTC
the problem might be that the uncompressed ecw is more than 10GB, it could be too much for ArcMap to handle as a jpeg.
Try using the Tiler to split it into 4 or 16 tiles and see if that helps.
David
jamal
  • Jun 9, 2014 8:23 AM UTC
Thanks David.
I’ll see if the manufacturer of the ecw image can split it so that the uncompressed size gets less than 10GB
Best
Jamal
