convert kml into dwg
terezia86
I tried to convert kml into dwg, but the schema of attributes is empty.
How can I get all the attributes from KML into the dwg?
thanks
arnold_bijlsma
Forum|alt.badge.img+14
Have a look at this Knowledge Base article: https://knowledge.safe.com/articles/19918/how-to-expose-feature-attributes-from-kml-tag.html
Depending on the data structure inside your KML file, it is very unlikely that the XQuery in the example applies to your data structure as well, so have a read through all the comments below the article as well.
Forum|alt.badge.img+32
  • November 5, 2019
If you select a feature and then look at the Feature Information window (normally on the right) you might see some information about how the attribute data is structured in your kml file
terezia86
  • November 5, 2019
hi @arnold_bijlsma and @trentatsafe,
unfortunatelly looks my KML a little bit different.
Any ideas how to define HTMLToXHTMLConverter (if) and XQuery?
Thanks
  • November 5, 2019
the use of a sdf file could solve your situation for your items with informations but you could loose some AutoCAD features
terezia86
  • November 6, 2019
Hi @ebygomm,
sorry I did not describe it good enough. Yes, I can see them after selecting them on the right corner, but I need to have the feature attributes in the table.
Thanks
