Convert excelsheet format by unique value
  • Dec 13, 2017 4:56 PM UTC
  • 8 replies
  • 71 views
Hi guys,
I have a lookup table contains values in different fields (column), example as below.
Is there a way I can make the all values become field names then give yes/no in each fields of the feature class?
Feature Class Field 1 Field 2 Field 3 contour_height_pts surveydate elevation vert_datum contour_minor surveydate elevation vert_datum contour_major surveydate elevation vert_datum Drainage feature linetype instaldate modifydate Culvert linetype instaldate modifydate
Thank you
fmelizard
Forum|alt.badge.img+22
  • Dec 13, 2017 5:54 PM UTC
Hi @lisasays, do you have an example of the output you'd like to see? Would you have elevation as a field name once or multiple times? How would the Y/N be populated?
  • Dec 14, 2017 1:29 AM UTC
Thank you Tia. I want elevation as a field name only once.. The output i want is as below
  • Dec 14, 2017 6:03 AM UTC
Hi @lisasays, this workflow example might help you.
The point is to use the value of an attribute as a new attribute name to create desired attributes that store the value "Y".
Result
Hope this helps.
  • Dec 14, 2017 6:14 AM UTC
Result
Hope this helps.
Another thought. JSON operations could be effective in this case.
JSON Template Expression:
    fme:get-attribute("Field 1") : "Y",
    fme:get-attribute("Field 2") : "Y",
    fme:get-attribute("Field 3") : "Y"
  • Dec 18, 2017 2:13 AM UTC
Thanks a lot Takashi. Since my lookup table is quite big, is there a way it can automatic get the list for "Attribute to expose" in JSONFlattener?
  • Dec 18, 2017 3:46 AM UTC
Unfortunately there is no way to expose attribute names automatically. However, if you have an external table (e.g. CSV or Excel spreadsheet) that contains all possible field names, you can add the AttributeExposer instead of setting the Attributes to Expose parameter in the JSONFlattener and import the field names from the table.
  • Dec 18, 2017 5:26 AM UTC
Result
Hope this helps.
This workflow would be robuster. Assuming that names of the target attributes are formatted in "Field<space><one or more digits>". Note: If "Field *" attribute can contain <empty> or <null>, remove them (i.e. change them to <missing>) with the NullAttributeMapper before the ListExpressionPopulator.
    for $name in fme:get-list-attribute("_list{}")
    return {$name : "Y"}
  • Dec 19, 2017 5:20 AM UTC
Great thanks a lot! This perfectly solved my problem :)
