Clipper bring wrong result...
  • January 23, 2017
Hello, got wrong result through clipping function: lines which are out of the Clipper-Area are in the Output as Clipper_inside. Can someone tell me the reason? Workbench with input-Shapes are attached.
  • January 23, 2017
  • January 23, 2017
itay
Forum|alt.badge.img+17
  • January 23, 2017
Very strange! looking more into it shows the Spatial Relator creating the correct result (does not intersect) and setting the Clippees on Clipper Boundary on outside results in the lines returned as outside which can mean that the clipper is somehow still detecting the boundry of the clipper.
I would contact Safe about this.
  • January 23, 2017
Thank you! I checked also the Relations of polygone to lines through LineOnAreaOverlay: brings to correct result - lines are not on polygone.
  • January 23, 2017
I think it's a known bug since FME 2017 RC does not exhibit this behavior.
You can test the 2017 RC with your dataset, according to the change log there are a lot of improvements to the Clipper: http://www.safe.com/support/support-resources/fme-downloads/beta/
  • January 23, 2017
Thank u for information. Im using FME 2016. And also have still FME 2015: just checked - this process works correct in it but works wrong in FME 2016.
itay
  • January 23, 2017
I wonder if this is still an issue in the latest 2016 version, I am using 2016.1.0.1 here, otherwise 2017 or 2015 is the answer....
  • January 23, 2017
I use FME 2016.1.2.0. The Problem is that Workbenches which were made in this Version i can't proper open and process in FME 2015. And FME 2017 i'm not allowed to install because of the Company rules... Not good! :(
  • January 23, 2017
I tested with 2016.1.3.0 b16709 and the bug was still there.
itay
  • January 23, 2017
Maybe but just maybe, since I cant speak for Safe, you should contact them to ask for assistance....
gio
Forum|alt.badge.img+15
  • January 23, 2017
@greenzone
the Clipper gets the blames.
The 3 input objects are self intersecting. (have 3 vertices in a switchback move..)
Use Chopper by 2 on them and then a Matcher 2D lenient. Input the 3 single matched into Clippee input port...now the are correctly treated as outside.
  • January 23, 2017
gio wrote:
@greenzone
Thanks for sharing the workaround.
You're right about the switchback, but it is clearly a regression in the Clipper since it used to work in FME 2015 and now works again in 2017.
  • January 24, 2017
@gio thanks for Information! As for me: it is not about blaming, it is about having tool doing what it did, without searching for Workarounds.
