Change all raster values of one pixel if all bands all three bands are 0
  • October 12, 2018
  • 5 replies
  • 132 views
jeroen
Forum|alt.badge.img+15
I'm trying to merge different raster features to one image using the overlap value option in the RasterMosaicker. My end goal is to merge these images based on how the look in RGB. The order of the layers is done using the sorter just before the merge. Using the transparency is key because you need to see the different layers when there is "a NoData pixel"
The problem i'm facing now is that the NoData values differs with each raster or even that some rasters do not even have a NoData value (even do it should). For the last situation i want to translate the raster a bit so the can be used for a NoData value of 255. By visual inspection i could see that that only the withe (r=0,g=0,b=0)colour needs to be replaced with transparency.
My first step is converting all 255 values in RED8, GREEN8 and BLUE8 to 254 so 255 is freed. For the next step i would like to do covert only the RED8, GREEN8 and BLUE8 values of a pixel that all three have the 0 value to 255. I tried using the RasterCellValueReplacer with the settings with and between  0 and 0  to be set to 255 and then setting the NoData value to 255 but the problem is that all 0 values are converted. Meaning that a red area (254,0,0) changes colour.
TLDR: Is there a value mapper kind of tool that could do the following (sudocode) trick:
1IF pixel == RED8 = 0 AND GREEN8 = 0 and BLUE8 = 0
2 RED8 = 255 AND GREEN8 = 255 AND BLUE8 = 255
3otherwise:
4 Do nothing
Best answer by jdh
You can do that with a RasterExpressionEvaluator conditional statement
If (A[0] == 0 && A[1] == 0 && A[2] == 0, 255, A[0])
If (A[0] == 0 && A[1] == 0 && A[2] == 0, 255, A[1])
If (A[0] == 0 && A[1] == 0 && A[2] == 0, 255, A[2])
jdh
Forum|alt.badge.img+40
  • October 12, 2018
jeroen
  • October 12, 2018
Got an error saying that it only accepts 3 arguments.
12018-10-12 17:06:25|  20.2|  0.5|ERROR |Expression Evaluator: The 'if' function requires 3 argument(s), but was provided with 4 argument(s)
2
32018-10-12 17:06:26|  20.5|  0.0|ERROR |A fatal error has occurred. Check the logfile above for details
4
So i changed it to:
But without a good result. How should i set the interpretation? Both the following settings did not work:
jdh
  • October 12, 2018
2
4
So i changed it to:
It should work.  I tend to use Preserve Interpretation, unless I have a reason not to.
conditionalallbands.fmw
  • October 12, 2018
2
4
So i changed it to:
Try changing the order of bands to Red8, Green8, Blue8.
jeroen
  • October 12, 2018
Setting it on Preserve did the trick. Thanks a million!
