Calculate coordinates of the center of a line
  • January 6, 2015
  • 9 replies
  • 399 views
Dear FME community,
I want to calculate the coordinates of the center point of a line with 2 points (begin and end point). The resulting coordinate (x,y) should be stored in two attributes, i.e. x_middle and y_middle.
I've solved it with a series of transformers, but that's not very elegant. Perhaps somebody has an idea if there's a more easier way to do this.
Kind regards
Thomas
  • January 6, 2015
Hi Thomas,
1) You don't need to calculate diffs.
x_middle = (_x_begin + _x_end) * 0.5
y_middle = (_y_begin + _y_end) * 0.5
2) The center of a line segment is equal to the center of its bounding box, so you can calculate the (x, y) based on the bounds coordinates that can be extracted with the BoundsExtractor.
x_middle = (_xmin + _xmax) * 0.5
y_middle = (_ymin + _ymax) * 0.5
3) The two expressions can be performed by an AttributeCreator.
Conclusion.
You can replace those transformers with a BoundsExtractor and an AttributeCreator.
Takashi
  • January 6, 2015
Another thought.
If you use @Coordinate function, just one AttributeCreator is enough.
See here to learn more about FME Functions.
FME and Factory and Function Documentation (http://docs.safe.com/fme/html/FME_FactFunc/index.html)
gio
Forum|alt.badge.img+15
  • January 6, 2015
For a single line segment consisting of just to vertices you can of course just use Snipper.
Snippingmode: percentage.
Start:50
End:50
this gives you the centerpoint of the line.
Extract coordinates if needed.
gio
  • January 6, 2015
..two vertices..
  • January 6, 2015
Many thanksTakashi. Tested both one's, and they work like a charm! :)
What I don't understand is why the functions @Coordinate and @Evaluate don't show up in the menu of my arithmetic editor. Shouldn't they be selectable from the left list? With manual inserting it works however.
Kind regards
Thomas
  • January 6, 2015
Som many possibilities with FME :) Thank you Gio!
  • January 7, 2015
Hi Thomas,
Almost all the FME functions are wrapped with transformers. For example, the CoordinateExtractor internally calls @Coordinate function; the BoundsExtractor calls @Bounds function.
If you are interested in the internal of transformers, look at this file in your system with a text editor. But, be careful not to destroy the file!
<FME HOME>\\transformers\\fmesuite.fmx
Since transformers can be used easier and safer than using FME functions directly, probably Safe intends to recommend users to use transformers unless there is a specific reason. The situation is similar to Python/Tcl use.
I think that's why only few functions are shown in the Arithmetic Editor.
And it is also the reason that I suggested BoundsExtractor+AttributeCreator first ;)
Takashi
  • April 5, 2017
This could also be achieved with the CentrePointExtractor.
  • April 5, 2017
Good catch. In FME 2016+, the CenterPointExtractor would be the simplest solution.
