CAD polyline to polygon. Some polylines don't create areas even though they should.
  • Feb 20, 2018 12:53 PM UTC
  • 5 replies
  • 79 views
I have the problem that some areas don't become polygon. Don't know why. I tried using snapper and line closer but that did not work. The polylines need to remain as they are in the dwg file.
I have sent you a zip file with workbench and dwg file.
This is the result I get. Almost correct.
You can see in this picture that some lines are missing. Anyone have any ideas how to solve this?
pratap
Forum|alt.badge.img+12
  • Feb 20, 2018 1:07 PM UTC
Which layers we have to consider?
Pratap
  • Feb 20, 2018 1:15 PM UTC
Pratap
I need the layer autocad layer and all attributes that begin with PL_L or PL_Y. What I need to do is create a fme workbench that can be used in FME server for similar files. But it can not drop any areas.
gio
Forum|alt.badge.img+15
  • Feb 20, 2018 5:20 PM UTC
Use a geometryfilter on the autocad file.
Then a intersector followed by a snapper (endpoint 0.1)
Extender 0.1, strechted. Again intersector then areabuilder.
This will build all the area's.
gio
  • Feb 20, 2018 5:22 PM UTC
  • Feb 21, 2018 6:13 AM UTC
Thank you very much Gio!Perfect solution for my workbench!
Best regards
Jesper
