BulkAttributeRenamer - unexpected attribute removal in FME 2025.0
kalbert
Forum|alt.badge.img+12
Just recognized, after migration of a workspace from 2024.2 to 2025.0 a BulkAttributeRenamer shows strange results: The transformer is set to change attribute names to lowercase (mode rename) for a selected set of attributes. This works as expected. However the remaining attributes (not selected for any change) got almost completely removed. ‘Almost completely’ means from the >5000 records only 4 have the attribute after the transformer while all other records show the attributes as <missing>.
@safe - although it’s easy to mitigate it might be worth to dig into it.
note: in mode ‘keep original attributes’ results are as expected.
Klaus
Forum|alt.badge.img+49
It sounds a lot like an issue I reported to Safe back in november:
“… attributes that were renamed by a BulkAttributeRenamer were unexposed after passing through a FeatureTypeFilter if the Update button was used to populate the list of feature types. If the feature type name was added manually there was no issue and everything worked as it should.”
That was filed as FMEFORM-32399 by ​@DanAtSafe
nielsgerrits
Forum|alt.badge.img+53
I very recently heard something similair from a teammember (attributes being unexposed after a transformer in 2025) but I have not been able to reproduce it. Happy to hear it is already reported!
nielsgerrits
Ah this is different. We found the PoinOnLineOverlayer unexposing attributes. Sample attached. Ticket submitted.
DanAtSafe
Forum|alt.badge.img+18
  • March 28, 2025
@nielsgerrits Unfortunately merged attributes were unexposed in the PointOnLineOverlayer, PointOnAreaOverlayer and LineOnAreaOverlayer. These issues were recently fixed via FMEENGINE-86065; I’ll let you know when the fix is available to download.
DanAtSafe
  • March 28, 2025
Hi ​@kalbert Are you using a FeatureTypeFilter after the BulkAttributeRenamer? If not, please submit a case via safe.com/support
@redgeographics The “problem” you saw with the FeatureTypeFilter was intentional as of FME 2022.0 Some users had requested that feature type output ports honor the original Feature Type settings. We could consider adding an option for the user to pick the behavior they want.
kalbert
  • April 1, 2025
Hi ​@DanAtSafe I submitted a case. The attribute removal I’ve reported has nothing to do with any following transfomer.
DanAtSafe
  • April 4, 2025
@kalbert FYI, the problem with the BulkAttributeRenamer in FME 2025.0+ has been filed as FMEENGINE-86480.  We’ll let you know when it’s been fixed.
