AutoCAD Lines to Points and include Point ID
  • September 20, 2019
  • 5 replies
  • 49 views
Hello All,
Im trying to extract the points (in order) of an AutoCAD line. Ive managed to extract the points, the coordinates and do most of the workflow, but I cant get the Point ID.
In the attached, Im looking for an additional column that will give me Point IDs 1,2,3,4 etc per l;ayer.
itay
Forum|alt.badge.img+17
Hi @cfordigan,
You can use a Counter transformer, group by the layer (counter name = 'your layer name')
You can rename the resulting attribute in the transformer (e.i _count = ID)
Or...
Use the FME Feature Function Count in an attribute creator ( more advanced)
Hope this helps,
Itay
Forum|alt.badge.img+32
If you use a CoordinateExtractor to extract all coordinates to a list, instead of chopping, you can then explode the list into points, and the index of each point will be written as an attribute
Awesome! It works and I love FME!
itay wrote:
Hi @cfordigan,
Or...
Hope this helps,
Itay
Thankyou! Worked
itay wrote:
Hi @cfordigan,
Or...
Hope this helps,
Itay
Used the counter too. Thankyou!
