autocad extended data
  • March 12, 2015
  • 15 views
franco69
Hi Guys,
easy question but I do that for my first time.....
i have ca. 10 different shape files which I convert into a dwg (fan output with autocad_layer)
how can i say FME that I want certain attributes of each shape file write into extended data from certain layers.?
Means....which parameter is responsible to write shape file attributes into a layer extended data?
And....when i have many different shape files which i convert in different layers with different attributes how can I handle that when I fan out them with an attribute?
Greetz
Franco
Best answer by gio
Just add the attributes to your writer. They will become extended data.
Take care to use the "AutocadMap3D extended data" writer.
gio
Forum|alt.badge.img+15
  • March 12, 2015
